CSM:Drop connection when wrong http header
mruuth
Level 3
Level 3
Hi All,
My securitypeople want me to drop connections if a http header , like PISA_ID is coming from a client. I don´t need to look into the header, just drop connection if the header is there. Any suggestion to solve this will be welcome. I am running version 4.2.7
Mats
Hello Mats,
Sorry for that.  I overlooked something in the documentation.  The policy has to have a serverfarm associated with it.  So if you create a dummy serverfarm with some IP address that the CSM cannot reach, it should start working as expected.  See my modified example below:
map DROP-PISA_ROLE header
  match protocol http header ROLE header-value *
serverfarm DUMMY
  nat server
  no nat client
  real 1.1.1.1
   inservice
serverfarm WEB
  nat server
  nat client NAT
  real 10.10.10.211
   inservice
  real 10.10.10.212
   inservice
  probe TCP
policy DROP-PISA_ROLE
  header-map DROP-PISA_ROLE
  serverfarm DUMMY
vserver WEB
  virtual 192.168.180.91 tcp www
  serverfarm WEB
  persistent rebalance
  slb-policy DROP-PISA_ROLE
  domain test.drop.header
  inservice
Let me know if this does the trick for you.
Sean
5 Replies 5
Sean Merrow
Level 10
Level 10
Hello Mats,
The CSM can do this.  You would need to configure a map to look for the header, then call out that map in a policy.  If a policy does not have a serverfarm associated with it, it will not load balance the connection.  In my example below, connections with the PISA_ID header will not be load balanced, but connections without it will be load balanced to the default serverfarm specified under the vserver.
map DROP-PISA_ID header
  match protocol http header PISA_ID header-value *
serverfarm WEB-SERVERS
  nat server
  no nat client
  real 10.20.5.66
   inservice
  real 10.20.5.67
   inservice
  probe HTTP
policy DROP-HEADERS
  header-map DROP-PISA_ID
vserver WEBSITE
  virtual 10.253.15.100 tcp www
  slb-policy DROP-HEADERS
  inservice
You should check out the documentation on maps, policies, and header parsing for more details.
Hope this helps,
Sean
smerrow (2010-02-24 15:41):
mruuth,
A new message was posted in the Discussion thread "CSM:Drop connection when
wrong http header":
https://supportforums.cisco.com/message/3024592#3024592
Author : Sean Merrow
Profile : https://supportforums.cisco.com/people/smerrow
Hello Sean,
Thankyou for your fast reply. Your "parameter header-value *" solved my problem,
because I just want to check the header and not the content. I shall now
implement and test.
Regards¨
Mats
Message:
Hello Sean,
I have tested but it does not work. I see with sniffer that the header is there, but no hit. Have tested with value AS and AS*
Any suggestions
Mats
vserver V180091
serverfarm SFT780-21
inservice
CR10#vserver v180091 det
V180091, type = SLB, state = OPERATIONAL, v_index = 465
  virtual = 192.168.180.91/32:80 bidir, TCP, service = NONE, advertise = FALSE
  idle = 3600, replicate csrp = none, vlan = ALL, pending = 30, layer 4
  max parse len = 2000, persist rebalance = TRUE
  ssl sticky offset = 0, length = 32
  conns = 0, total conns = 9
  Domains:
    test.drop.header
  Default policy:
    server farm = SFT780-21, backup =
    sticky: timer = 0, subnet = 0.0.0.0, group id = 0
  Policy          Tot matches  Client pkts  Server pkts
  DROP-PISA_ROLE  0            5            6
  (default)       9            161          237
Hello Mats,
serverfarm DUMMY
  nat server
  no nat client
  real 1.1.1.1
   inservice
serverfarm WEB
  nat server
  nat client NAT
  real 10.10.10.211
   inservice
  real 10.10.10.212
   inservice
  probe TCP
  serverfarm DUMMY
vserver WEB
  serverfarm WEB
  inservice
Sean
Hello Sean,
It did the trick.Great help from you.
Many thanks
Mats
Message was edited by: mruuth Besides, how do I put in rating?
