CSM failover
tbui
I have two CSMs located at different cities (VA and MA). In CSM, it has a feature that you can make one CSM is active and the other CSM will be standby in different 6500 chassis.
In my case, I have one 6500/CSM at Virginia and 6500/CSM at Boston. They are on different network (they are in routed network). How do I make the active/failover work in different subnet and what is the configuration looks like. Thanks
Cisco show me that create 1 vlan for active/failover, but the CSMs are in the same subnet.
Gilles Dufour
what kind of connection do you have between the 2 sites ?
Do you have a Layer2 link between the 2 ?
Are you using the same subnet at each site ?
I would personally not configure them is active/failover scenario.
I would simply configure each site separately and use a redirect on the main site pointing to the backup site when this one is down.
This is what I explained to you in the other question you posted.
Gilles.
Gilles,
I understandthe use of redirect on the main site point to the backup site when all server in local site are down.
The most I concern was, if the entire local site is gone (example: the building including network equipment, CSMs, router, ect...)
The link between Virginia and Boston is 6MB circuit ( layer 3 link, NOT in layer2) but Virginia site and Boston are in our routed network. Is there a way that I can configure each of CSM in different subnet, going through a routed network (not routed through Internet) and still perform a Active/Failover on the CSMs.
I am using a different subnet between the 2 (Virginia and Boston).
What kind of Cisco device that can do this funtion (Active/Failover) through a routed network.
Theo
