CSM predictor forward and throughput
Martin Kyrc
Level 6
Level 6
hello,
can me anybody tell, how is limited CSM throughput using predictor forward? in other words I have two interfaces/vrfs on the cat6k and these networks are routed through CSM (some traffic is load balanced on the CSM) and my question is, if it's any bandwidth reason to route this non-LB traffic somehow without CSM.
thanks a lot
martin
Gilles Dufour
the CSM itself has some limitation in amount of connections it can handle and traffic it can pass through.
So, the max is 1 million active connections and the total BW in and out is 4Gig.
The fact that you use forward or another predictor does not change.
It still counts as connections and BW.
Gilles.
