csm probe problem
fchristie
Visitor
I have the following problem after configuring/setting up tcp probe:
probe TCP tcp
interval 10
failed 30
vserver test:3389
virtual x.x.x.x tcp 3389
serverfarm test
inservice
serverfarm test
real a.a.a.a
inservice
real b.b.b.b
inservice
real c.c.c.c
inservice
probe TCP
Vserver shows o.o.s
serverfarm shows o.o.s probe failed for all servers
when I show probe, I get:
real vserver serverfarm policy status
a.a.a.a:3389 test:3389 test (default) OPERABLE
I have a separate VIP setup for each server without a probe and I can connect to them on port 3389, so I know
the application/servers are ok.
The csm is running ver 3.1(4)
Can you explain why the probe shows operable yet the serverfarm shows probe_failed?
Gilles Dufour
if you remove the probe, is the vserver inservice ?
I would also recommend to test with a software more recent.
There was some probe issues in the past and they should be fixed with new releases.
Gilles.
