CSM reseting web connections to VIP
p-lees
Hi - I have a CSM which is configured to load-balance 2 web-servers initially. I have the following config in place;
module ContentSwitchingModule 4
vlan 102 client
ip address 192.168.8.33 255.255.255.240
gateway 192.168.8.34
vlan 104 server
ip address 192.168.9.1 255.255.255.240
probe HTTP http
request method head url /index.html
expect status 200 299
interval 20
port 80
serverfarm ROUTE
no nat server
no nat client
predictor forward
serverfarm WEBFARM
no nat server
no nat client
real 192.168.9.10
inservice
real 192.168.9.11
inservice
probe HTTP
vserver VIP
virtual 192.168.8.35 tcp www
serverfarm WEBFARM
no persistent rebalance
inservice
vserver REAL_ACCESS
virtual 192.168.9.0 255.255.255.0 any
serverfarm ROUTE
inservice
When i try to access the Vip i am getting the following debug output from the CSM card.
Jul 25 21:55:35.151: CSM4:
LB: TYPE:0 LENGTH:128 CNTR:0x16 SEQ:0x103 ID:0x1fffca COMMAND: L7 NEW SESSION
sessionID:0x1fffca sessionID_Seq:0x103 vserverID:0xa RLID:0xa
DST IP:192.168.8.35:0 SRC IP:81.149.150.244:2290 Enacps:0x7ffd
Jul 25 21:55:36.123: CSM4:
LB: TYPE:1 LENGTH:128 CNTR:0x17 SEQ:0x103 ID:0x1fffca
L7 COMMAND: Dest-Decision Cmd
Failed LB : access-denied
I can ping both servers, and the probe is showing that both servers are up on port 80, but yet i am still seeing "access denied" when i try to connect to the VIP. What i actually see in a sniffer trace is that the CSM sends a TCP RST.
Anyone got any ideas ??????
Thanks in advance
Gilles Dufour
can we get a 'sho mod csm x real' and 'sho mod csm x vserver'.
Do you get the RESET just after the SYN ?
Are you sure you do not need 'nat server' ?
In other words, are your server ready to accept connection on the vip address ?
Do you have any other vserver that you did not mention ?
Gilles.
Hi Giles - the NAT Server did the trick.
Many thanks for this
