CSM-S bridge mode design
bogdahnt
Hi all,
I have a CSM-S module in a Cat65xx system and working on my design. The MSFC is on the client side and the server and client side at the CSM should be in the same subnet (so bridge mode!?).
How can I integrate the SSL daughtercard (DC)? Can I use the DC in the same subnet/vlan? If not, which other possibility I have to use the DC in this configuration? Thanks in advance
Thomas.
15 Replies 15
do the following on your ssl-dc
conf t
ip route 0.0.0.0 0.0.0.0 10.6.78.1
telnet and ping are considered management traffic. The management traffic has its own routing table that is not the same as the production traffic.
The management route is configured in global config with the 'ip route' command.
NOT the "route" command under the proxy-vlan.
Gilles.
