CSS 115003 Configuring HTTP Compression (not work)
dimaonline
Community Member
I need configure HTTP Compression by hardware on CSS 11503. I make config like this http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/css11500series/v8.10/configuration/ssl/guide/Compress.html#wp1031247
My config:
service s1
  ip address 10.1.66.11 (web server)
  keepalive type none
  compress enable
  slot 3
  compress encode force-gzip
  compress accept-omit gzip
  active
  content C1
    vip address 10.1.65.31
    protocol tcp
    port 80
    url "/*"
    add service s1
    active
But web site respond and not compress of my traffic:
CSS11503# show version
Version:               sg0810106 (08.10.1.06)
Flash (Locked):        08.10.1.06
Flash (Operational):   08.10.1.06
Type:                  PRIMARY
Licensed Cmd Set(s):   Standard Feature Set
CSS11503# show chassis coprocessors
Configuration for CSS11503-AC L0:
Product Name:    CSS11503-AC L0     SW Version:        08.10.1.06
Serial Number:   JMX124051AY        Base Mac Address:  00-22-55-68-ef-91
Coprocessor Inventory:
Slot/SubSlot    Coprocessor    Version    Active
   3/1          COMPRESSION       11      OPERATIONAL
CSS11503# sh service s1
Name: s1                Index: 5
  Type: Local            State: Alive
  Rule ( 10.1.66.11  ANY  ANY )
  Session Redundancy: Disabled
  Redirect Domain:
  Redirect String:
  Keepalive: (NONE   5   3   5 )
  Keepalive Encryption:      Disabled
  Last Clearing of Stats Counters: 01/18/2012 04:53:19
  Mtu:                       1500        State Transitions:            6
  Total Local Connections:   17          Total Backup Connections:     0
  Current Local Connections: 1           Current Backup Connections:   0
  Total Connections:         17          Max Connections:              65534
  Total Reused Conns:        2
  Weight:                    1           Load:                         2
  Weight Reporting:          None
  Compression Type:          ASCII
  Compression Encode:        Force-gzip
  Compression Accept-omit:   Gzip
  Compression TCP settings:
    Virtual TCP Inactivity TO:    240      Server TCP Inactivity TO:    240
    Virtual TCP Syn Timeout:      30       Server TCP Syn Timeout:      30
    Virtual TCP Ack Delay:        200      Server TCP Ack Delay:        200
    Virtual TCP Fin Timeout:      30       Server TCP Fin Timeout:      30
    Virtual Min Retrans Timer:    500      Server Min Retrans Timer:    500
    Virtual TCP Nagle Algorithm:  enable   Server TCP Nagle Algorithm:  enable
    TCP Receive Buffer:           32768    Server TCP Queue Delay:      750
    TCP Transmit Buffer:          65536
  Compression Statistics:
    HTTP Responses In:                                                 1
    Compressed HTTP Responses Out:                                     0
    Bypassed HTTP Responses Out:                                       1
    HTTP Response Bytes In:                                          262
    Compressed HTTP Response Bytes Out:                                0
   Bypassed HTTP Response Bytes Out:                                262
    Compression Ratio Percentage:                                     0%
  # of connections closed/reset due to:
    Unknown Method:                      0
    Pipelined Data:                      0
    Client Tag Format:                   0
    Server Tag Format:                   0
    Internal Error:                      0
  # of files bypassed due to:
    Method:                            0  Status:                            4
    Client Version:                    0  Server Version:                    0
    Accept-Encoding:                   0  MD5 or Encoded:                    0
    File Extension:                   15  Content Type:                      0
                                          Data Too Small:                    6
    C-Bypass Total:                   15  S-Bypass Total:                   10
________________________________________
HTTP session on Internet Explorer:
GET / HTTP/1.1
Accept: text/html, application/xhtml+xml, */*
Accept-Language: ru-RU
User-Agent: Mozilla/5.0 (compatible; MSIE 9.0; Windows NT 6.1; WOW64; Trident/5.0)
Accept-Encoding: gzip, deflate
Host: 10.1.65.31
Connection: Keep-Alive
HTTP/1.1 200 OK
Content-Length: 1433
Content-Type: text/html
Content-Location: http://10.1.65.31/iisstart.htm
Last-Modified: Thu, 24 Mar 2005 11:19:08 GMT
Accept-Ranges: bytes
ETag: "05eb54b6330c51:4a6"
Server: Microsoft-IIS/6.0
X-Powered-By: ASP.NET
Date: Wed, 18 Jan 2012 11:35:42 GMT
<html>
<head>
<meta HTTP-EQUIV="Content-Type" Content="text/html; charset=Windows-1252">
Daniel Arrondo Ostiz
Good morning,
To troubleshoot this further, you will need to get simultaneous traffic captures on both sides of the CSS and capture the test connection.
Looking at the traffic, we should be able to see why compression is not taking place.
Daniel
See attachment. This is TCPDUMP session
10.1.3.65 - client
10.1.66.254 - CSS (as router) in server network. HEAD from it - this is keepalive ping for other service.
At first sight, I don't see anything wrong with it, so I would recommend you to open a TAC service request to have this investigated in more detail.
Daniel
I have no SMARTnet subscription for TAC support service. CSS is bought 3 years ago.
If I would have an access to TAC that I would not communicate in a forum.
