CSS 11501 - Network reconnection issue
maha
Using a CSS 11501 switch to configure both Load balancing and server hot standby between two servers (of same config). Clients are connecting to the server using tcp/ip sessions.
The configuration used is shown below:
configure
ip route 0.0.0.0 0.0.0.0 10.167.50.1 1
!************************* INTERFACE
interface e2
bridge vlan 9
interface e3
bridge vlan 9
!************************** CIRCUIT
circuit VLAN1
ip address 10.167.50.108 255.255.254.0
circuit VLAN9
ip address 10.167.70.1 255.255.254.0
!************************** SERVICE
service abc_service1
ip address 10.167.70.2
protocol tcp
port 6300
keepalive type tcp
active
service abc_service2
ip address 10.167.70.3
protocol tcp
port 6300
keepalive type tcp
active
!*************************** OWNER
owner xxxxx
content abc_crule
vip address 10.167.50.109
add service abc_service1
add service abc_service2
protocol tcp
port 6300
balance aca
active
We conducted three tests to verify the hot standby while client sending the data to server app thro tcp/ip.
1) Brought down the service on one server 2) Restarted the OS (Windows 2003) on one server 3) Removed a network cable of one of the server connecting to CSS.
client app lost the conn to the service/server, but when it tried reconnecting to the alternate server, it was successful.
CSS status reflected the actual status of the service/server.
But in third test (removing network conn) the service state changed from "Alive" to "Down" and client app lost conn to the server. Client app tried reconnecting and it was successful connecting to the alternate server.
But when we connected the network cable back, the CSS state was continue to be in "Down". Also,the network connection between CSS and server was not available after reconnection. Also, the status of alternate server changed to "Down", but still client app was successfully transmitting to the alternate server. Stopping the client app and tried reconnecting,
the connection was not going thro.
The connection could be established between CSS and server boxes only after restarting the OS(running windows 2003).
Issues:
1. Service status in CSS continue to be down even after reconnecting the cable with the service running.
2. CSS status of the first service also went down after reconnecting the other server.
3. Client app could not reconnect to any of the servers.
Are we missing any configuration parameter in CSS which will address the above?
regards
Param
Gilles Dufour
Param,
what software version for the CSS ?
Did you see an ARP entry on the server for the CSS ?
Did you see an ARP entry on the CSS for the server ?
is the server directly connected to the CSS or is there an L2 switch inbetween ?
Could you configure 'bridge spanning-tree disabled' on the CSS and see if this improves the situation.
Gilles.
