CSS 11501 problem with cookie and load balancing
pamirian76
Level 5
Level 5
hi and thanks for reading,
the css works fine, I can load balance using balance leastconn but I'm having some problems using cookie.
here is what I have,
content web
add service myserver1
add service myserver2
vip address 1.0.76.19
port 8443
protocol tcp
balance leastconn
active
but when I change it to
content web
port 8443
protocol tcp
advanced-balance arrowpoint-cookie
active
with this nothing works.
actually I don't really understand who creates the cookie. does the CSS create the cookie in the client browser or an empty cookie must exist prior hitting the css?
any examples out there with some good explaining? I've done alot of reading on this site but still don't understand how this cookie sticky sessions really works.
thank you very much!!
melchib
Level 3
Level 3
Hi.
This is an older document, but it might help you out:
http://www.cisco.com/warp/public/117/AP_cookies.html
drex_72
Community Member
In your "mrserver1" & "myserver2" service, add the following:
string
For instance:
service myserver1
ip address 10.10.10.5
keepalive port 80
protocol tcp
string myserver1
active
service myserver2
ip address 10.10.10.6
keepalive port 80
protocol tcp
string myserver2
active
cschneid
Typically you would add the following two
options to the content rule if you want to use
arrowpoint-cookies:
url "/*"
However, this only works for http based connections. I see that you are using port 8443 and suggests that possibly this is an SSL content rule and not an http content rule. If it's SSL, then arrowpoint-cookie won't work for you in this content rule.
Regarding who creates the cookie, it's the CSS. It generates a session based cookie that is good as long as the browser is open (there are several options that can be configured for this but this is the default behavior).
Hope this helps.
-Chip
