CSS 11506 running 08.20.2.01
raneema
Can you tell me if this will work?
keepalive type encrypt
keepalive method get
keepalive port xxxx
Specifically, what can I do for a layer 5 KAL for HTTPS in a service? I hate to compare these things but I know on an F5 I can do an https get.
These are 11506 running 08.20.2.01
Thanks for anything you can advise,
jason.espino
You can definitely setup the CSS to perform a URI keep-alive over HTTPS.
keepalive type http encrypt
However, in order for this configuration to work properly your CSS must contain the SSL module as the service will need to be setup as a "type ssl-accel-backend". This will allow the CSS to encrypt the keep-alive request and decrypt the servers response using the cert/keys defined within the backend-server configuration within the ssl-proxy-list.
Does your CSS contain an SSL module?
- Jason
