CSS 11506 - SCM CPU load
Sbutzek
Level 3
Level 3
we have about 30 CSS Devices, mostly 11503.
But we have also 4 11506 in our Network.
On These 4 CSS Devices, we se much highter CPU Load on the SCM CPU, we are monitoring.
Since we did a softwareupgrade from 5.20 Build 6 to 7.20 Build 109 we se much highter CPU Load on these Devices.
Serval times, there are peaks at 100% CPU Utilisation. The duration from those peaks vary, up to 2 hours.
The peaks are independet from traffic. Also our IOMs are only loaded at max 10% CPU Util.
Any idea, what this could be?
On Our 11503 Devices, the Peaks are not over 50% Utilisation on the SCM. Mostly they are at 20%.
Best Regards
Gilles Dufour
At the time of the problem, you can do from debug mode :
GILLES(debug)# cpu hog 1 1
CPU Hog Debug Options (1/1)
d) Display data
Please enter selection [q=Quit]:d
Checking CPU Hog
TID Name Milliseconds
0x8c462d70 apIdle 2
0x8e24aea0 tNetTask 1
0x8a6a00a0 AS_0000012b.I 1
0x8df80bf0 SysTimerHandler 1
0x8bce05d0 tFlowMgrPktRx 1
Do this many times to see if this is always the same process consuming the cpu.
Reason for high cpu could be logging level set to debugging (make sure it is set to level 4), too many
scripted keepalives, ...
Another possible reason is this bug :
CSCec83724
Source Group Portmappings decrease with # of modules and ASR
If you have ASR configured and source group, you may run out of ports so the CSS will loop looking for a free a port.
Gilles.
Hello Gilles,
thanks for your reply, but i did not get an idea whats the reason, by using the CPU hog.
I always get output like this:
Checking CPU Hog
0x8a39afe0 tSyncReq 0
0x8dfc7150 ImmGetAgent 0
0x8a412b20 AS_00001786.I 0
0x8c44fa70 apIdle 0
0x8bccd2d0 tFlowMgrPktRx 0
Checking SemID = 0x00000000
TID Name sem MilliSecs
d) Display data
Checking CPU Hog
0x8c44fa70 apIdle 0
Even if show system-recources shows me 80% CPU Usage.
I also seen, that the CPU Spike seems to occur on both systems at the same time.
There is no traffic on the system, because it is a test enviroment. We use source-nat for outgoing traffic from our servers to DNS Servers, but there are ony a few connections.
The bug CSCec83724 is resoved, but what Version does a fix include?
So what can i do to get out the right task.
We do not use scripted keepalives, only HTTP and TCP.
Best Regards
Sven
indeed the CPU hog did not provide information to decide exactly what process is the culprit.
But it is one of the 5 listed there.
Here is another procedure to capture the cpu info.
symbol-table load SPRITZ
shell 1 1 spy
wait a couple of minutes
shell 1 1 spyStop
shell 1 1 spyReport
symbol-table unload SPRITZ
Regarding the bug it will be integrated in the next 7.40 image.
Gilles.
