CSS & CE Reverse Proxy Caching - Freshness and Content - Help !!!
networks
Community Member
We have a pair of 11054's and a pair of 570 CE and a pair os SCA's and using them in a RPC configuration in front of a series of static content web servers.
My problem is I want the CE's to server content even when the origin server(s) are down but where the content is cached fresh or not. So of if the cache has the content, serve it no matter what its freshness. I don't want to have a sorry server used unless the content isn't cached at all.
Or can I pre-position content on the same CE and have it server from there. What content types can be prepositioned ? Is someone going to tell me I need a content router now of something ?
Anyone have any bright Ideas ??
Simon
ciscomoderator
Administrator
Administrator
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
ngorenko
Level 2
Level 2
Hi Simon,
If you plan to cache and pre-load (replicate) data in the same device, you need to look at new sw for CE (ACNS 4.2). It has possibility to provide both functions of caching and replication for one CE. CSS has a special feature: to upload (based on threshold) "hot" content to CE.
If you are not a big content provider, you do not need a special content router. Content routing is very tricky things. It could be implemented in the different platforms. For example, CSS also could perform content routing functions.
