Css flow timeout on routed traffic
Sbutzek
Level 3
Level 3
i am confided how the css handels the Flow-Timeout on connections witch are going over a Content rule or a Group.
This can be controlled via the flow-timeout-multiplier which is configured per rule or group.
But how are routed connections handeld?
They have a timeout of 16 seconds if there is no other timeout specified for the TCP Port.
So if a flow is timed out and the client or server is sending data on this connection, is there a tcp-rst generated from the css or will there be a new flow generated and the packed is routed as any normal L3 switch does?
I am asking, because we have changed some timeouts on content rules on the a css which does the SLB.
Another css is also in the path, because it does FWLB and SLB in another direction.
Also i have a question about debuging?
Is there a way to see if a 3-way handshake has been perfomed between Client and Server?
Sometimes i see some flows (llama; flow-agent show fcb-detail) which have no bytes transfered, but they are timing out after 120 sec inactivity.
Best Regards
Sven Butzek
Gilles Dufour
You can control the timeout with the command 'flow port1 timeout ' [only in recent releases].
For the SYN question, I would say you have to check the 'frame in' counter in the 'flow-ag show fcb 0x...' or 'flow display 0x...'
Flow statistics bytesIn = 1371 framesIn = 7
Gilles.
Hello Gilles,
the flow portx command is as you said only abiable in recent releases.
I think in SG Version it is not implemented.
Theres a flow port permanent statement.
Both of the commands do only work for 10 TCP Ports.
I do not understand why this feature is not implemented the same way as it is for the content rules.
Also my question is not fully replied.
Does the css also cut routed flows that timed out and sends a rst packet, or does it build up a new flow?
Best Regards
Sven Butzek
The 'flow port timeout' exist in 7.40
The routed flow will also timeout.
However, when the next packet comes in, a new flow can be created if there is no Nating involved.
[no sourcegroup].
Gilles.
Hello Gilles,
thats what i want to know.
So there will be no problem with the timout.
Best Regards
