CSS Hard Drive
wilson_1234_2
Level 7
Level 7
We have two CSS devices that are set up to forward the Web requests.
There is a hard drive on each unit.
What is stored on the hard drive?
Is there a typical use for the Hard Drive that maybe I could be using that I am not?
diro
Level 6
Level 6
A css can has 2 bays which can be either filled with a harddisk or a flashdisk. These bays can be seen if you unscrew the cover on the front of your css. These disks will store the OS (up to 3 or 4), config files, log files, dump files ...
