CSS - How to Load a script
raquelitaciska
Community Member
hello,
I wonder if anybody can explain how to load a script to run with CSS 11050.
many thanks
Raquel
pknoops
Level 7
Level 7
Hi Raquel,
Do you mean a custom script or one of the canned scripts that ship with the CSS ?
If you want to load a custom script file, simply ftp to the CSS.
Once connected to the CSS via FTP (you will be in the running code directory when you ftp into any CSS), CD to "script". Once in this directory, you can "put" the file into the directory. Do not use any file extensions here.
Now, from the CSS cli, you can do a "script play filename" where filename is the name of your script. If you want to see what scripts are there (to see if your file is there correctly), do a "script play ?"
If you need further direction, feel free to reply here. You can also have a look at the following link:
http://www.cisco.com/univercd/cc/td/doc/product/webscale/css/css_500/advcfggd/appa.htm
Pete Knoops
Cisco Systems
Hello Pete,
Thanks a lot for your reply. I meant custom script; the link you pointed contains a lot of usefull information on this.
Best Regards
Raquel
