Flow timeouts. Better Solution?
CCampbell_2
Level 5
Level 5
We use the CSS to load balance terminal server sessions (TCP/3389). We used to have people getting disconnected all the time until we added flow-timeout 2700. Which I forget the conversion but is something like 12 hours. I'm wondering is there a better way to do this? Maybe with the flow permanent port1 3389 command or flow long-lived?
This is for a CSS11503 running in routed mode. Here is a cutdown config, flow stats & show ver.
service SERV21
keepalive type tcp
keepalive port 3389
keepalive maxfailure 2
ip address X.Y.Z.151
keepalive frequency 30
active
service SERV22
keepalive type tcp
keepalive port 3389
ip address X.Y.Z.152
active
owner TriWest
content TSFarm
vip address A.B.C.21
flow-timeout-multiplier 2700
add service SERV21
add service SERV22
AGGREGATE FLOW STATISTICS PER-SP
Flow Manager Statistics - Slot 1, Subslot 1:
Cur High Avg
UDP Flows per second 1 723 1
TCP Flows per second 5 853 2
Total Flows per second 6 1178 3
Hits per second 0 133 0
Number of Allocated Flows (non-purged) 711
Number of Free Flows 64825
Number of Allocated fast-path FCBs 711
Number of Free fast-path FCBs 130361
AGGREGATE FLOW STATISTICS PER-PORT
Port Active Total TCP UDP
# 1/1-20 1 1499330 1 0
# 1/1-21 280 28557120 275 5
# 1/1-231 131 64849808 9 122
# 1/1-232 11 1040578 11 0
# 1/1-233 1 166485 1 0
# 1/1-234 287 207016381 258 29
CSS11503(config)# sh ver
Version: sg0730106 (07.30.1.06)
Flash (Locked): 07.20.2.06
Flash (Operational): 07.30.1.06
Type: PRIMARY
Licensed Cmd Set(s): Standard Feature Set
Secure Management
Gilles Dufour
each connection consumes resources of the CSS.
This is why there is the concept of idle flow being garbage collected.
You can adjust the timeout with the flow-timeout as you did.
You could also disable timeout with flow-permanent.
[you can forget flow long-lived].
The risk when playing with this is that you prevent the CSS to claim back unused resources.
So you may end-up with no resource available for new connections.
If you go for flow-permanent, you should monitor level of resources with a 'flow stat'.
Make sure the number of free FCB is above 5,000.
Gilles.
