CSS issue...can't reach default gateway..
gavin han
I've issue with CSS. I've static route configured on CSS but CSS can't ping the default route and hence it isn't able to reach radius server.
and default route is also not coming up in "sh ip routes" table.
another question is:
if I do "sh ip interfaces" then vlan interface state comes up as "noCircuit". what does that mean, this status comes up because this box is in standby mode, it is not a master?
Please advise how to resolve this issue. how do i get default route in routing table so that it can reach our network.
I'm into a tight situation.
Thanks...
Gilles Dufour
Is your gateway on the management interface ?
If so, the static route need to be configured in a special way
http://www.cisco.com/en/US/partner/docs/app_ntwk_services/data_center_app_services/css11500series/v8.20_v8.10/configuration/quick/guide/Setup.html#wp1160987
For example, to configure a static route for the Ethernet management port, enter:
(config)# ip management route 172.27.59.0 /24 172.16.6.100
Also, check your interface with the command 'show circuit'
Gilles.
