CSS load balancing problem
Branimir Turk
Level 3
Level 3
I have two CSS that I use to load balance RDP connections to two WTS servers. I dont have switch behind CSS so they are connected back-to-back via cable. All server facing ports (including back-to-back ports) are in the same VLAN.
CSS1 is primary for the VIP address and for redundant interface address, and CSS2 is standby.
So, when I connect WTS-1 to CSS-1 and WTS-2 to CSS-2, CSS1 sees both services as active and everything seems fine. If WTS-2 is disconnected, WTS2 service on CSS1 is down etc.
In sticky table, I can see that CSS1 is load balancing request to both servers, but the problem is that only RDP connections to WTS-1(server directly connected to CSS1) work fine , and connections that are load balanced to WTS-2 are dropped??? Direct RDP connection to WTS-2 IP works fine.
If I connect WTS-2 to CSS1, so both WTS servers are connected to CSS1 everything works fine.
Can anyone tell what can be wrong?
Configurations are in the attachment.
Thanks for help.
Branimir
Gilles Dufour
try the command 'ip uncond' on both CSS.
It will guarantees that the response from WTS-2 comes back to CSS1.
Gilles.
