CSS Management Ethernet Routing
graham.harper
Hi I have a CSS 11501 running 7.40 we are trying to get routing working through this port using
ip management route x.x.x.x <Mask> Next Hop
We can Ping the Next Hop but cannot get to the route end point. We have verified Layer 3 connectivity as we have other devices (Non CSS) in this VLAN.
Has anyone else seen this issue? Or will I have to use one of the Normal Ports.
Cheers
-G
Gilles Dufour
what kind of route is it ?
/32 or /24 or did you try a 0.0.0.0/0 ?
Is it overlaping another route from the regular routing table ?
Gilles.
I have tried a /32 and a /24 both fail. The Network doesnt overlap with the production network.
what software version do you use ?
Did you verify with a sniffer trace if traffic was sent to the nexthop ?
Gilles.
Giles Looks like it is all solved we rebooted the box and all seems to work now.
