CSS: Mgt port for management vs normal port for Maqnagement
s.srivas
What are the pros and cons of using the ethenet management port for managing a CSS and using a normal ethernet port for managing a CSS.
Is any functionality of CSS depends on Management ethernet port? Is connecting via local lan still an issue/requirement?
Gilles Dufour
you can use whatever port.
People usually wants to use a management port that is *separated* from the rest of the device so that if a regular port gets hacked and somebody gain access to the device, you can't access the management network.
To obtain this separation between regular port and the management port, a lot of restriction have been created on the management port.
You can't configure a default route on the management port, you can't have routes overlapping between management port and regular ports, ...
Therefore, personally, I prefer not to use the management port. The chance that somebody gain access to the CSS via a regular port is almost null so it does not justify the pain to use the management port.
Gilles.
Gilles Dufour
Gilles.
Thank you Gilles. Ver usefull information. I've come accross both implementations and this information is very usefull.
