CSS newbie - 8.10 upgrade problem
keithredding
Community Member
I typed the config from our working 11503 7.10 CSS into a new 11503 8.10 CSS. Show Run for each is identical (see attached). When I swap-in the new CSS I get "Page not found" from the VIP, and all the 8.10 CSS will do is bridge me to the real server addresses. What have I missed?
NB 8.10 CSS has SSL module and license.
Gilles Dufour
I have seen this kind of things in the past.
Often it is cable misconnected or arp table of gateways/servers still pointing at the previous CSS even if disconnected.
So, clear all arp table on gateways and servers.
Then verify they learn the new CSS mac address correctly.
Then verify connectivity using ping.
Then use a browser.
If it still does not work, capture a sniffer trace in front of the CSS.
Gilles.
Thank you Gilles - thought about ARP, but forget about the servers' ARP entries for the CSS.
Will let you know the outcome.
Keith
