CSS Possible Crash - Help to Decode
alanwright1
Level 3
Level 3
Hi Folks,
A Customer CSS 11503 may have crashed, can you tell from the top of the core dump, the reason, or do you need the entire dump?
The top part is as follows:
DUMP ?@ À ??^Œ
Software: 7.10 Build 504
Build Timestamp: Thu_01/29/2004___5:23p
Unit: CSS11500 (SCP)
Slot: 1 Subslot: 1
Memory Size: 256MB
Dump Type: 'Task Level Exc' (1)
Dump Timestamp: JUL 24 13:10:18
Current Task: 'tFlowMgrPktRx' (0x8bceed50)
Vector Number: 3
Bad PC: 0x80759928
Bad Address: 0x10c
Cause Reg: 0x8000000c
Flash (operational): 08.10.1.06
Header Rev: 3
BR
Alan
mchin345
Level 11
Level 11
Login and enable the llama debug and use " dump nvram show 1 1 " command you will get all the information needed to identify the bug you encountered.
http://www.cisco.com/en/US/products/hw/contnetw/ps792/products_tech_note09186a00802d3891.shtml
