CSS redundancy box-to-box
georges.merhej
Hello guys,
I'm planning to install 2 redundant load-balancers in a DMZ zone. The CSS units to be installed behind 2 ASA firewalls working in Active/Standby mode. What are the recommendations for these requirements?
1-Do we use the box-to-box redundancy?
2-Do we connect every server to the 2 CSS units with teamed network cards?
3-How does the ASA failover if any of the CSS goes down?
Thanks everybody for you help.
Georges.
Gilles Dufour
box-to-box redundancy is slot to failover compare to vip/interface redundancy.
Moreover, it prevent the use of ASR - so no stateful failover.
Avoid teamed network card with the CSS.
If you want to use such thing, insert a switch between CSS and server.
Don't know anything about ASA failover. Check with the appropriate forum for ASA questions.
Gilles.
Hi Georges,
Here is the URL for the configuration for the Configuring VIP and Virtual IP Interface Redundancy follow the configuration guide which may help you
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/css11500series/v8.20_v8.10/configuration/redundancy/guide/VIPRedun.html
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/css11500series/v8.20_v8.10/configuration/redundancy/guide/ASR.html
Configuring Box to box redundancy:
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/css11500series/v8.20_v8.10/configuration/redundancy/guide/Redndncy.html
CSS 11500 Active-Active Stateful Failover ASR in One-Armed Mode Configuration Example
http://www.cisco.com/en/US/products/hw/contnetw/ps792/products_configuration_example09186a00802206a3.shtml
Box-to-Box Redundancy on the CSS 11xxx Configuration Example - Ciscowiki
http://supportwiki.cisco.com/ViewWiki/index.php/Box-to-Box_Redundancy_on_the_CSS_11xxx_Configuration_Example
Kindly find full range of configuration examples on CSS here :
Cisco CSS 11500 Series Content Services Switches
Configuration Examples and TechNotes
http://www.cisco.com/en/US/products/hw/contnetw/ps792/prod_configuration_examples_list.html
http://supportwiki.cisco.com/ViewWiki/index.php/Category:Cisco_CSS_11500_Series_Content_Services_Switches
Kindly see URL given below for my other articles
http://boardreader.com/fp/Cisco_Systems_Networking_Profe_309110/Application_Networking_543840.html#hot_threads
If possible plz rate so that I can be helpful to other people also as it will enhance my credibility.
Sachinga.hcl
