CSS scripting - How to build an auto YES answer in script files
vnovakov
Community Member
Hi all,
I have about two hundred services that I would like to remove using a script.
Unfortunately to remove the service you need to confirm it typing Y in console:
CSS-(config)# no service service1
Delete service <service1>, [y/n]:y
CSS(config)#
How can I bulid this automatic "Yes" answer in my script file?
Best regards,
Vladimir
dario.didio
Level 9
Level 9
You can go into expert mode, where no confirmation is asked to make changes to the config of your CSS. Everything is applied directly, without the confirmation question.
you enable it by simply typing
CSS#expert
to disable it
CSS#no expert
Have a look at following document:
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/css11000series/v6.10/configuration/administration/guide/Profiles.html#wp1015667
Hope this helps
