CSS SSL blade
s.soni
Community Member
Hi Gilles
With respect to the SSL blade on the CSS how can I have it configured for the following.
I have one web instance 10.1.1.1:2011. It has a certificate on it "cert" and one domain. Now I want it to service 2 more domains using the certificate cert_a and cert_b. Can I do this? How do I go about this?
Thank you
Soni
Gilles Dufour
you simply create new ssl_server in your proxylist.
Something like this :
ssl-proxy-list MyList
ssl-server 10 rsakey KEY-A
ssl-server 10 rsacert CERT-A
ssl-server 10 vip address x.x.x.xA
ssl-server 20 rsakey KEY-B
ssl-server 20 rsacert CERT-B
ssl-server 20 vip address x.x.x.xB
You need a new vip address or a new port for each domain. You can't use the same ip:port for different domain because the decryption process starts before we can determine which domain is contained in the HTTP header.
Gilles.
