CSS to ACE 4700
fmacioce
Is there a command on an ace  that is equivalent to the CSS configuration command      flow-timeout-multiplier?
Michael Berger
In ACE, you will have to set the idle timer via a connection type parameter map and apply it to the class, inside the multi-match policy:
cdn-ace-2/bermicha(config)# parameter-map type connection TIMER
cdn-ace-2/bermicha(config-parammap-conn)# set timeout inactivity ?
  <0-3217203>  Inactivity timeout (default TCP 3600, UDP 120, ICMP 2)
cdn-ace-2/bermicha(config)# policy-map multi-match POL
cdn-ace-2/bermicha(config-pmap)# class NAT_46
cdn-ace-2/bermicha(config-pmap-c)# connection ?
  advanced-options  Specify connection advanced parameters
cdn-ace-2/bermicha(config-pmap-c)# connection advanced-options TIMER
Michael
