CSS UDP source group sticky problem
scain
Community Member
I have a CSS 11503 that we use to balance SIP calls(UDP) among our SIP servers.
We have a content rule that balances the incoming traffic and a source group to NAT the outbound traffic. Both the content rule and the source group use the same IP address.
When a SIP call arrives at one of our servers through the VIP an entry is created in the sticky table based on the sip-call-id as expected. But when we initiate a call from one of our SIP servers an entry is not created in the sticky table. When the remote SIP server responds the CSS sees a new sip-call-id and load balances the call instead of sending it back to the originating server.
Is there a way to add an entry to the sticky table for the sip-call-id when a source group is used?
Here is the pertinent config:
circuit VLAN2
  ip address 10.10.1.3 255.255.255.0
    ip virtual-router 25
    ip redundant-interface 25 10.10.1.1
    ip redundant-vip 25 10.10.1.233
    no redirects
circuit VLAN3
  ip address 10.10.2.3 255.255.255.0
    ip virtual-router 52
    ip redundant-interface 52 10.10.2.1
    no redirects
service SIP03
  ip address 10.10.2.233
  redundant-index 130
  active
service SIP08
  ip address 10.10.2.238
  redundant-index 180
owner test
  content sip-udp-test
    application sip
    port 5060
    protocol udp
    flow-timeout-multiplier 38
    vip address 10.10.1.233
    redundant-index 103
    balance weightedrr
    add service TalkingSIP03 weight 1
    add service TalkingSIP08 weight 1
    advanced-balance sip-call-id
    active
!*************************** GROUP ***************************
group sip-udp-test
  redundant-index 200
  add service SIP03
  add service SIP08
  portmap disable
A call comes into 10.10.1.233 on udp 5060, is load balanced to 10.10.2.233(SIP03), and an entry is added to the sticky-table for the sip-call-id.
When SIP03 starts a call to remote server 1.1.1.1 using source group IP 10.10.1.233 a sticky-table entry is not added for the sip-call-id and when 1.1.1.1 sends a response it is load balanced to either SIP03 or SIP08.
How can I keep the call that was initiated on SIP03 on SIP03?
Steven
chrhiggi
Level 8
Level 8
Steven-
  The "vip address" on your content rule is what matches the inbound traffic.  Your outbound traffic is initiated to 1.1.1.1 which is not a vip ip, hence, it doesn't match the content rule.  On the reverse - the response is mapping to a vip ip since the source was the natpool.  I would assume that 1.1.1.1 server already had a connection through the vip and/or something changed slightly about the flow that classified it as a new inbound connection instead of re-mapping back through the sourcenat pool.
Chris
scain
Community Member
I think this problem is unique to UDP.
I assume there is an existing flow with the sourcenat when 1.1.1.1 responds. Is there a way get the CSS to use the flow in this instance instead of load balancing?
