CSS11050 content protcol any problem
moorthy1977
Level 3
Level 3
owner TEST
content TEST_VIP
add service TEST1
add service TEST2
vip address a.b.c.d
protocol any
active
hi i want to configure above conf in content switch.but protcol any is not working.please suggest how can add both udp as well as tcp protocol in content find below Version
CSS11050# sh ver
Version: ap0500105 (5.00 Build 105)
Flash (Locked): 3.10 Build 33
Flash (Operational): 5.00 Build 105
Type: PRIMARY
Licensed Cmd Set(s): Standard Feature Set
Enhanced Feature Set
6 Replies 6
Zach Seils
Level 11
Level 11
What do you mean by "is not working"? "Any" is the default, so if you don't specify a protocol, the rule will accept both tcp and udp by default.
Is it that you don't see it in the config?
~Zach
Thanx for u r reply but it does not accepts the default config.
error is
CSS11050(config-owner-content[TEST])# protocol any
CSS11050(config-owner-content[TEST])# active
%% Protocol of TCP or UDP must be specified
defualt setting is not taking same error i am getting.
please let me know if any IOS related problem or something else.
Do you have a port specified in your content rule? I didn't see one in your example above ...
If you need to specify a port, then you have to specify a protocol -- so you'll need two (2) different rules to support tcp and udp.
~Zach
Thanks for u r reply.
Please find the configuration.
if u can tell me how to go ahead with current config.
interface e1
bridge vlan 105
!************************** CIRCUIT **************************
circuit VLAN105
ip address 172.16.8.1 255.255.255.128
!************************** SERVICE **************************
service DNS-1
ip address 172.16.8.2
active
service DNS-2
ip address 172.16.8.3
active
!*************************** OWNER ***************************
owner DNS
content DNS-VIP
port 53
add service DNS-1
add service DNS-2
vip address 172.16.8.1
protocol udp
active
!*************************** GROUP ***************************
group DNS-Group
vip address 202.138.8.10
add destination service DNS-1
add destination service DNS-2
If you want to allow DNS over TCP, you would need the following added to your configuration:
owner DNS
content DNS-TCP
port 53
add service DNS-1
add service DNS-2
protocol tcp
active
~Zach
My problem is solved.please find below config.I removed the command port 53 & it is taking protocol any.
content DNS-TCP
add service DNS-1
add service DNS-2
protocol any------well this is hidden while u take config.ican enter this command without any problem
active
thanks for u r your
