CSS11500 vrrp problems
sgeorgiev
Community Member
I have two CSS11503 in ASR Master/Backup configuration. The configuration worked correctly for two years, but one week ago the Backup CSS become the Master without any configuration changes. So now and two CSS work as Master and I have not service! I reboot the Backup one and after reboot it?s become master again. I think that the VRRP problems are occurs. I saw that the Backup CSS didn?t receive VRRP information:
CSS2(debug)# ip scp statistics
Packets received with supported protocol types:
IPPROTO_IP: 0 IPPROTO_ICMP: 804
IPPROTO_IGMP: 8 IPPROTO_GGP: 0
IPPROTO_TCP: 1829 IPPROTO_EGP: 0
IPPROTO_PUP: 0 IPPROTO_UDP: 179
IPPROTO_IDP: 0 IPPROTO_TP: 0
IPPROTO_EON: 0 IPPROTO_OSPF: 1451
IPPROTO_ENCAP: 0 IPPROTO_VRRP: 0
IPPROTO_OSPF: 0
How can I troubleshooting the problem and could I check if the Master CSS send VRRP packets? I have not rebooted the master CSS yet!
Gilles Dufour
There is a known ddts that makes the CSS stop doing VRRP after 828 days.
If your master has been up for that amount of time, you need to reboot it.
The ddts is CSCek37489
Gilles.
Uptime:
CSS5-SCM-2GE F0 : 834 days 00:13:38
CSS5-IOM-16FE F0 : 834 days 00:13:36
CSS503-SM-INT : 834 days 00:13:36
Thank you very much Gilles! Early in the morning I will reboot the machine.
Thanks again!
That was the problem! Now it is OK!
Thank you!
