CSS11501 Slow per connection performance
7gtattersall
I'm seeing an issue with our CSS 11501 (SW vers 08.10.1.06) units where the per-connection (flow?) throughput is very slow. It appears to be capped around 100kBps.
CSS port 1 has an internet uplink on n.n.n.1. The CSS vlan IP is n.n.n.2/27 (via circuit vlan 1065).
The servers are plugged directly into the CSS. They are in the same vlan and ip space, ie. n.n.n.13, with default gateway n.n.n.1.
My issue is that an individual http download, whether coming to/from one of the servers behind the CSS, is getting very poor throughput. Each http "flow" seems to be capped at 100Kbps or less.
Can anyone point out why this is happening and how I might resolve/avoid the issue?
Gilles Dufour
could you first check if the problem exist or not when bypassing the CSS.
Are you going directly to the server via the CSS or do you hit first a content rule and the CSS loadbalances the connection to a server ?
If loadbalancing, the type of content rule is very important, so we will need a copy of it.
Also, capture a trace on the server and the client [simultaneous] to see where there could be inter-packet delay.
Gilles.
There is no throughput problem if the CSS is bypassed, ie, the server is connected directly to the same switch as the firewall, and has it's default route set to the gateway ip address of the firewall. I can pull the full 100Mbit/s FD in this configuration, but the CSS doesn't see the traffic, so no load-balancing.
The network layout has changed slightly since my first posting, but I'm still seeing a throughput issue for the devices connected/routing out via the CSS.
I have now also raised this with Cisco TAC.
Outside LAN -- LAN1/28
usage: firewall public vip and Internet
Inside LAN -- LAN2/27
usage: firewall inside vip
CSS LAN2 vip (redundant-interface)
CSS content vips (redundant-vip)
CSS01 LAN2 interface address
CSS02 LAN2 interface address
Server LAN -- LAN3/28
usage: CSS LAN2 vip
App Servers
DB Servers
Admin Servers
CSS01 LAN3 interface address
CSS02 LAN3 interface address
The servers (services) are defined like this :
service web01
redundant-index 1
port 80
protocol tcp
keepalive type tcp
keepalive port 80
ip address LAN3.35
active
service web02
redundant-index 2
port 80
protocol tcp
keepalive type tcp
ip address LAN3.36
active
Load-balanced vips (content) are defined like this :
content website
protocol tcp
vip address LAN2.11
port 80
sticky-inact-timeout 60
flow-reset-reject
add service web01
add service web02
redundant-index 101
advanced-balance sticky-srcip
active
LAN1, LAN2, and LAN3 are all publicly accessible Internet addresses (subject to the firewall placed between LAN 1&2). NAT is not used.
Any thoughts about why a single connection (flow) is slowed down dramatically when talking to either the servers that are placed in LAN3, or the VIPs placed in LAN2.
GT
I have the same setup in the lab and have no issue.
We will need a simultaneous sniffer trace on client and server.
Also, what is your CSS software version ?
Gilles.
I didn't notice your reply coming in, apologies for the delayed response.
I managed to find some time yesterday to take a fresh look at the problem, and was able to resolve my issue.
The problem was not with the CSS afterall. The operating system was bringing the network card up as 100Mbit Half Duplex, despite us telling it to use 100FD.
I had to reset everything to Autonegotiate to get it all running as 100FD. I'm now able to pull data across the CSS at the full 100Mbit/s speed (10MB/s).
Thanks for helping look into this.
Graeme.
