CSS11506-load balancing problems(no service hits)
Roble Mumin
Level 3
Level 3
I need some help regarding "least connection" load balancing of 4 web servers.
I configured a rule and 4 services which in generally work fine. According to my understanding of least connection, the servers should be used equally or at least in a manner that every service gets a hit once in a while. My Current problem is that only sevice 1/4 gets regular hits. Service 2/4 gets reduced hits, 3/4 very few hits and 4/4 no hits at all.
Does anyone have an explanation for this behavior?
Have a look @ the summary:
CSS11506-1# sh summary
Global Bypass Counters:
No Rule Bypass Count: 1346787
Acl Bypass Count: 0
Owner Content Rules State Services Service Hits
PP1_Owner PP1-Rule Master
PP2_SAS00454 19643
PP2_SAS00455 8369
PP2_SAS00456 745
PP2_SAS00457 0
The Content/Owner Rule :
CSS11506-1# sh running-config owner PP1_Owner
!*************************** OWNER ***************************
owner PP1_Owner
content PP1-Rule
vip address <vipaddress1>
redundant-index 10
advanced-balance sticky-srcip
add service PP2_SAS00454
add service PP2_SAS00455
add service PP2_SAS00456
add service PP2_SAS00457
balance leastconn
active
content PP1-Rule2
redundant-index 11
protocol tcp
port 80
url "/"
redirect "//portal.saspf.svc/SAPPortal"
active
The four HTTP Services:
ip address <myip1>
redundant-index 54
keepalive uri "/irj/servlet/prt/prtroot/MemoryGame.Default"
keepalive port 8100
keepalive frequency 15
keepalive retryperiod 15
keepalive type http
active
ip address <myip2>
redundant-index 55
keepalive port 8100
keepalive type http
active
ip address <myip3>
redundant-index 56
keepalive port 8100
keepalive type http
active
ip address <myip4>
redundant-index 57
keepalive port 8100
keepalive type http
active
Gilles Dufour
least conns means that any time t, all the services should have the same amount of ACTIVE connections.
But if you look the number of total connections, you do not see the same amount.
This is perfectly normal.
ie: you open 1 connection, it goes to service 1.
You close the connection.
You open a new connection, it will also go to service 1 since all services have 0 active connections.
The total connections for service 1 is therefore 2 and 0 for all the others.
With this simple example you can understand why service 1 will always have much more connections in total than service 2, which will more than service 3,...
If you want the total connections to be same the same, you should use round-robin.
Gilles.
Gilles Dufour
Gilles.
Thanks for the info!
I understand the difference now. I also changed the LB Method to round-robin in the meantime and could see the difference first hand.
