Defining virtual servers using content-rules
ewhinger
Community Member
Can multiple virtual servers be "bound" to a single real server when all of the virtual servers have the same ip address and port, with the only difference between each virtual server being a unique content rule applied to each? (This is more of a migration issue, than a load-balance issue)
mmellet
Level 7
Level 7
I don’t see how you could configure that. You’ll probably have to schedule a down-time window for your migration. What platform are you moving from?
keithlui
Community Member
I assume you are saying Web(HTTP) and the answer is yes.
1. Your server should has name-based virtual hosting enabled if your server only use 1 IP address.
2. In CSS, you can use single service for this server or use different services with different keepalive uri for each service.
3. You can use a number of unique Content rules (same VIP, TCP 80 with different URLs) and add the service to it.
Remarks: If you want to use unique Content rules, you should make them difference with URL, otherwise all the content rules are the same and you can't activate all.
Another suggestion: If your server already support Name-VHOST, you can use just single L4 Content rule and all the traffic would be handled by that server (service).
