Difference between ACE module and ACE appliance
narayana reddy
Community Member
Hi All,
Can someone help to understand the difference between ACE module and ACE appliance, as i am observing ACE module is providing more throughput when compared the ACE appliance, Is the only advantage we getting with contexts ....
thanks inadvance,
Narayana Mallidi
asharmav
Level 5
Level 5
Hi Narayan,
Apart from providing throughput, ACE module has more to offer ,
http://docwiki.cisco.com/wiki/Cisco_Application_Control_Engine_%28ACE%29_Troubleshooting_Guide_--_ACE_Resource_Limits
The above link will provide a comparision of ACE module and Ace appliance interms of scalability. Apart from that legacy modules wont support compression, but ACE 30 module can support compression.
The major advantage of ACE 30 module is with resepct to SSL throughput, SSL TPS, L4 & L7 CPS, & Concurent Connections per second, apart from the increased contexts
ACE 4710 Data Sheet :
http://www.cisco.com/en/US/prod/collateral/contnetw/ps5719/ps7027/Data_Sheet_Cisco_ACE_4710.html
ACE20 Data Sheet
http://www.cisco.com/en/US/prod/collateral/modules/ps2706/ps6906/product_data_sheet0900aecd8045861b.html
ACE 30 Data Sheet
http://www.cisco.com/en/US/prod/collateral/modules/ps2706/ps6906/data_sheet_c78_632383.html
Abijith
