Differences between CSM and ACE
clarkmat
Community Member
Could someone give me a short answer on the differences betwenn CSM and ACE? For example if you configured an ACE in a DMZ can you still configure VIP with vserver command? Are the configurations similar? I know that the policy configuration is different but also wondered where you add the sticky feature config?
Gilles Dufour
they use different CLI.
But you can achieve with the ACE module everything you could with the CSM.
However, ACE is the brain new module and comes with extra new features and will receive even more in the future.
Gilles.
thanks Gilles
As the CLI is different will there be examples posted? I mean adding for example sticky configuration on the vserver is now added where exactly on ACE?
Matt
the documentation is online and examples will be posted once we collect information about what is most needed.
For stickyness, you configure the sticky group more or less like a CSM.
One difference is that you need to associate the sticky group to a serverfarm
You then go into your policy-map and instead of using a serverfarm you use a sticky-serverfarm which is the group you just created.
Very simply.
switch/Admin(config)# sticky ip-netmask 255.255.255.0 address source ?
Enter the sticky group name (Max Size - 64)
switch/Admin(config-sticky-ip)# serverfarm lin
switch/Admin(config)# policy-map type loadbalance first-match L1-STICKY
switch/Admin(config-pmap-lb)# class class-default
switch/Admin(config-pmap-lb-c)# sticky-serverfarm ?
Enter sticky group name (Max Size - 64)
IPSTICKY
Gilles.
