Do arrowpoint-cookies use "string range"?
gzkjgs
I can't find any document mentioning whether or not "advanced-balance arrowpoint-cookie" uses the "string range" setting in a content rule to determine how far to look down the cookie string to find the ARPT cookie. The default setting in the rule is "1 to 100", so if I have a cookie string that looks like this (from a sniffer trace):
HTTP: 12: Cookie: $Version=0; XSESSIONID=Qy8PilVehwrIFD8Fs6tqzbIhtSFe3Qer9Euu2qGE4Ygz1nx29238F0FuFPS!=1730213783!=2102771864!8161!7002; ARPT=OZOMIVS172.16.1.20CK00J; preloginFlag=yes; termsflag=yes
The arrowpoint cookie ARPT is more than 100 characters into the string, so will the CSS not see this cookie and send a new one (thereby rebalancing, possibly to a new server)? Or does advanced-balance arrowpoint-cookie always look through the entire cookie string?
I haven't been able to lab test this, so I was wondering if anyone knew for sure?
Paul
Gilles Dufour
Paul,
for arrowpoint cookie the CSS will look in the first 6 packets - whatever the size.
You can increase or decrease this value with the command
CSS11503(config)# spanning-packets ?
Integer value(Range: 1-20)
The string range has no effect for arrowpoint-cookie.
Gilles.
Thanks for rating this answer.
