Does Cisco ACE20 supports TLS 1.2
Please help us in knowing whether the TLS 1.2 is supported on Cisco ACE20, below are IOS details.
Show Version
Software
  loader:    Version 12.2[120]
  system:    Version A2(3.6a) [build 3.0(0)A2(3.6a)]
  system image file: [LCP] disk0:c6ace-t1k9-mz.A2_3_6a.bin
  installed license: ********************************
Hardware
  Cisco ACE (slot: 3)
  cpu info:
    number of cpu(s): 2
    cpu type: SiByte
    cpu: 0, model: SiByte SB1 V0.2, speed: 700 MHz
    cpu: 1, model: SiByte SB1 V0.2, speed: 700 MHz
  memory info:
    total: 825768 kB, free: 212732 kB
    shared: 0 kB, buffers: 4468 kB, cached 0 kB
  cf info:
    filesystem: /dev/cf
    total: 1014624 kB, used: 428400 kB, available: 586224 kB
If not, what is the next available version of hardware/software support this feature?..
If yes and how do we enable it on ACE-20.
Advance Thanks
Kanwaljeet Singh
ACE20 doesn't support TLS1.2 and ACE 30 as well as ACE4710 support TLS1.2 in version A530.
Pasting A530 release notes for your reference.
http://www.cisco.com/c/en/us/td/docs/app_ntwk_services/data_center_app_services/ace_appliances/VA5_3_x/release/note/ACE_app_rn_A53x.html#wp895341
Kanwal
Kanwaljeet Singh
Kanwal
