Does GSS supports http KA using digital certificate?
rgomes
I need to check web servers that permits only client access using the proper digital certificate.
Is there a way to import the certificate to the gss so it can run the http KA using the certificate.
I am not talking about the certificate to access the GSS GUI.
Any help is appreciated
Robson
Daniel Arrondo Ostiz
Hi Robson,
The HTTP KA on the GSS is very basic. It will just do a plain HTTP request against the server to see if it's alive. Unfortunately, client certificates are not supported.
Daniel
