Enable Multi Stream ICA parameter in WAAS(5.1.1c)
Hi all!
I have questions about the settings of Multi Stream ICA(MSI) in WAAS (ver 5.1.1c).
(1) Setting Parameter
* Enable only the parameter "Enable Multi Stream ICA" ?
* Is there other parameter for such quality of service(QoS)?
  We should set the parameters in WAAS?
  We don't have the information of how to set it and the meaning.
(2) Impact when enabling "Enable Multi Stream ICA"
* In our network, ICA stream go thourgh WAAS, but not MSI. If we enable MSI parameter, do outages of current ICA stream happen?
  If so, the outage means "connection failure happens"?
Regards, Satoshi
0 Replies 0
