Enable to create a sticky because as a resource is not allocated.
AndyGB5150
Afternoon all.
I hope somebody out there can help.
I would like to create a sticky session but after trying to create one the above message appears.
AndyGB5150
Sorry it should say unable rather than enable.
You have to allocate ressources for sticky groups in your ressource class for the context (check your config in the admin context)
Well after spending sometime on the problem this morning the stickyness has now stuck.
I did find out that if you select "Replicate to HA peer" this removes the config from the master HA.
The only way to get this to stick "Sorry" is to remove the HA link and manually add the sticky group and then the servers to the sticky group.
Thanks again.
