Flow-timeout-multiplier
STEVE FLIS
long story
During a cookie issues involving passing through 2 CSS units I opened a Tac Case.
During this case , I was advised to use the flow timout multiplier command as a possiblity in resolving the cookie issue.
Unique names on the cookie seemed to cure the issue. But, I did leave the flow timeout multiplier on the rule.
This has worked for well for many months.
above this CSS are a pair of proxies that take care of external access. These proxies are having problems under load. The logs from these proxies seem to indicate that sessions are staying open, TCP 3 way handsahake don't always close correctly etc.
My question is Do I really need the flow timeout multiplier set to 120 ( default 8 for http ) Is this contributing to the issue. Below is a cleaned up content rule
content appexternal
balance aca
add service appwwebprod01-appex
add service appwwebprod02-appex
add service appwwebprod03-appex
add service appwwebprod04-appex
vip address 1.1.1.1
primarySorryServer sorryTHIS
protocol tcp
port 80
url "/*"
advanced-balance arrowpoint-cookie
flow-timeout-multiplier 120
no persistent
arrowpoint-cookie name XXX01
active
Gilles Dufour
the CSS will not close the connections, even if you change the timeout multiplier.
Only the client or the server can close the connection.
Therefore, changing the timeout on the CSS will have no effect on the proxies.
However, it could break something on the CSS.
I would therefore not change the CSS timeout.
If you have control of the servers, reduce the timeout there.
This will force idle connection to be disconnected.
Gilles.
