Problems with script keepalive - socket waitfor command
michael.e.reid
Level 3
Level 3
Hi All,
We have a script keepalive running for 4 different services, two services are UP and the other two are DOWN. This is the part of the script that fails:
socket connect host ${192.168.255.100} port 80 tcp 2000
socket send ${SOCKET} "GET /keepalive.asp HTTP/1.0\n"
socket send ${SOCKET} "User-Agent: Mozilla/4.0 (compatible; MSIE 5.01; Windows NT 5.0)\n\n"
socket waitfor ${SOCKET} "this server is alive" 5000
socket disconnect ${SOCKET} graceful
The script is the same and the only difference was that the two that were up had a full stop (.) at the end of the 'this server is alive' string in the keepalive.asp page - however the script is not looking for a full stop (.) response ?
When the server guys added a . to the end of the 'this server is alive' string the service came alive.
Can anyone explain this behaviour ?
Gilles Dufour
you are hitting the following bug:
CSCeg46589
"Scripted keepalive may fail with Script error at socket waitfor"
when the data sent by the server is exactly the same as the waitfor text, then the css would fail to match the 2.
Gilles.
Thanks for rating this answer.
