FTP and backup serverfarm issue
rathinilesh
Hi All,
I am hitting a strange issue. For one of our clients, I have a VIP configured that serves FTP, HTTP and HTTPS. The config is as below. When I configure a backup serverfarm "http-maintenance.client.com-sf" under the loadbalance policy-map "CLIENT-VIP2-ANY-PM, passive FTP stops working. Active FTP continues to function properly so does HTTP and HTTPS. I am using ACE10 [version A2(3.5)].
Could anybody please advise ?
Nilesh
rserver redirect http-maintenance.client.com-redirect
  webhost-redirection http://maintenance.client.com/ 302
  inservice
serverfarm redirect http-maintenance.client.com-sf
  rserver http-maintenance.client.com-redirect
    inservice
serverfarm host CLIENT-VIP2-ANY-SF
  failaction purge
  predictor leastconns slowstart 60
  probe CLIENT-HTTP-80-PR
  rserver SERVER1
    inservice
  rserver SERVER2
    inservice
  rserver SERVER3
    inservice
serverfarm host CLIENT-VIP2-FTP-SF
  probe CLIENT-FTP-PR
  rserver SERVER1
    inservice
  rserver SERVER2
    inservice
  rserver SERVER3
    inservice
sticky ip-netmask 255.255.255.240 address source CLIENT-VIP2-FTP-SG
  timeout 15
  replicate sticky
  serverfarm CLIENT-VIP2-FTP-SF
class-map match-any CLIENT-VIP2-ANY-CM
  2 match virtual-address A.B.C.D tcp any
class-map match-any CLIENT-VIP2-FTP-CM
  2 match virtual-address A.B.C.D tcp eq ftp
policy-map type loadbalance first-match CLIENT-VIP2-ANY-PM
  class class-default
    serverfarm CLIENT-VIP2-ANY-SF
policy-map type loadbalance first-match CLIENT-VIP2-FTP-PM
  class class-default
    sticky-serverfarm CLIENT-VIP2-FTP-SG
policy-map multi-match CLIENT-VIPS
  class CLIENT-VIP2-FTP-CM
    loadbalance vip inservice
    loadbalance policy CLIENT-VIP2-FTP-PM
    loadbalance vip icmp-reply active
    inspect ftp
  class CLIENT-VIP2-ANY-CM
    loadbalance policy CLIENT-VIP2-ANY-PM
    connection advanced-options TIMEOUT
chrhiggi
Level 3
Level 3
Nilesh-
  Are you stating that you add the configuration in, and instantly all active ftp sessions grind to a halt? Or are you saying when you test your backup serverfarm configuration, the active sessions fail at that point?
  Chris Higgins
Hi Christopher,
Thank you for replying. Yes, when I add the configuration in, instantly all current/new ftp sessions stop functioning.
Nilesh
Nilesh-
  Sounds like a logic programming issue. Can you please get a TAC case opened to address this and report the bug ID back to the alias?
  Chris Higgins
