FTP and NAT static on CSM
irodi
I have a problem with the ftp from a server that try to connect via ftp to another IP crossing the CSM. This server is nated statically by the CSM.
Example:
module ContentSwitchingModule 7
static nat 161.1.1.1
real 10.10.10.1
real 10.10.10.2
Of cource the flow coming from 10.10.10.1 cross the csm then we have the nat and this is ok.
From 10.10.10.1 I do a ftp to another server 20.20.20.1. I put the password and everything goes ok, but do DIR I lose the connection because I receive a reset from the csm.
Is this possible?
Ira
Gilles Dufour
the problem is that when you do a dir, you need to open a data connection.
In active mode, the server [20.20.20.1] opens the connections back to the client [10.10.10.1] but in this case the client is nated to [161.1.1.1].
So a connection is open from 20.20.20.1 to 161.1.1.1 which comes to the CSM which does not know what to do with this new connection and drops it.
The server [20.20.20.1] is probably sending a RESET back to the client because it can't open a data connection.
If you try passive mode [type passive once the ftp connection is open], it should normally work as the data connection would be open by the client itself.
Gilles.
