gracefull shutdown weight or suspend
cebetant
Documentation describe the usage of weight to provide graceful server shutdown.
My testing with a telnet session is that you get a fairly graceful shutdown with the suspend command, telnet continue with the initial server until it end.
What is then the benefit of using weight?
Gilles Dufour
if you are using stickyness, if a server is suspended it can't be used.
However, if you changed the weight to 0, new connection hitting a sticky entry pointing to this server will still be forwarded to it.
This is for protocol like http which opense mutliple tcp connections while surfing a website.
Gilles.
Hello Gilles,
We're using ACE 4710 version A3(2.4), and the command "weight 0" is not allowed ?
This is different than the documentation "ACE 4700 series application control engine appliance command reference".
Is it a bug ?
