Groups question
wilson_1234_2
Level 7
Level 7
Is the concept of groups to keep the traffic flowing through the VIP address, to the multiple services added to the group?
This way, the connection from the client to the end machine (which ever service the original connection is made) stays intact?
I have seen questions about possible NATing and routing problems with the CSS and load balancing, is this what prevents those problems?
The routing stays through the CSS when groups are configured?
I have also seen FTP configured diferent ways with and without the:
application ftp-control
Is that needed as long as groups are configured?
content ftp
vip address 2.1.1.80
protocol tcp
port 21
add service MCI-FTP1
add service MCI-FTP2
group ftp-group
add destination service MCI-FTP1
add destination service MCI-FTP2
21 Replies 21
Hello Wilson,
This is an example about how an one-armed configuration for ftp should looks like:
FTP passive/active, and if you need to nat the incoming and the outgoing traffic:
content FTP
add service web03-1
add service web04-1
protocol tcp
port 21
vip address 10.90.208.50
active
group FTP
add service web03-1
add service web04-1
active
The acl would be like this:
acl 15
clause 10 permit tcp 10.90.208.0 255.255.255.0 any destination any sourcegroup FTP
clause 99 permit any any destination any
apply circuit-(VLAN1) < -- Content rules vlan.
Then in order to enable the acl you need to issue this command:
CSS(config)# acl enable.
http://www.cisco.com/en/US/products/hw/contnetw/ps789/products_tech_note0918
6a0080093de6.shtml
Now, regarding the groups, as per our conversation this is the difference of
add service and add destination service:
The "add service" command under the group will NAT traffic that is originated from the Servers, heading to the outside of your network. This traffic will be NATed if the servers wishes to open a connection to someone
else on the your outside network.
The "add destination service" command will NAT the traffic that is heading towards the Server, being load balanced to your servers. All traffic that is incoming to the server will be NATed to the VIP configured.
This a in line document:
http://www.cisco.com/en/US/customer/products/hw/contnetw/ps789/products_conf
iguration_example09186a0080093dff.shtml
Now, does not matter the default gateway of your servers since you are going to NAT on the CSS so, the server always should respond back to the CSS.
Please let me know if this make sense.
-Rodrigo
Ok Rodrigo
So are you saying that since I have a one armed config, I can use this (with the access-lists)for any circumstance where asymetric flows could be a problem?
And if I need to do this with SMTP or anything else, I just follow the example you have here is that correct?
Wilson,
That depends, if you are going to use active FTP you will need to use the group with add service and the ACL.
And if you are going to balance just passive FTP you can use just the group with add destination service, and you wont need the ACL.
It is easiest to use the groups instead of OSPF.
Regarding your question about SMTP, please check this example:
!************ SERVICE **************
service test
ip address 10.10.10.3
port 25
suspend
service test2
ip address 10.10.10.4
port 25
active
!************* OWNER ***************
owner L3_Owner
content SMTP
add service test
add service test2
vip address 10.10.10.2
port 25
protocol tcp
active
In your case since you have a one-armed, you will need to use a group with add destination service, in order to nat the incoming traffic.
- Rodrigo
what exactly is the acl doing?
Rodrigo,
Why wouldnt I want to use this method for all configured servers in the CSS with a one armed config?
It seems that with SMTP, if I send mail from inside our network, the server can go straight from the firewall to the router, then to the Internet, it could bypass the CSS and there could be problems with the remote server and reverse lookups.
My mail could be coming from the firewall NAT rather than the CSS VIP, correct?
Why wouldnt I ALWAYS want to make sure all traffic went through the CSS that originates from my servers configured with services?
And just to eliminate problems, it seems that if I had the choice, I would want all traffic to and from the CSS balanced server to go throught the CSS.
Is this correct?
Hi Wilson,
It is simple, if you are going to use the CSS to do load balancing for your mail servers, the users are going to open the connection with the VIP address that you are using to balance the SMTP traffic.
The server must send the responses back to the CSS, because if not, we are going to have an asymmetric flow.
The users are waiting the respond from the CSS (VIP address).
Now, this depends about what you need or what you would like to do, if you want you can send all the SMTP traffic from your PIX to your servers, and the servers are going to respond back to the PIX.
Since you have a one-armed, you need to use the group in order to NAT the incoming traffic in order to avoid the asymmetric flows. Or if you want you can do policy based routing on your switch or disable the sysopt noproxyarp on you PIX, use your CSS as the default gateway on your servers and use the command no redirects on the CSS, but I will prefer to use the groups.
Regarding your question, what exactly is the acl doing?
R/ there are a couple of things that we need to be clear.
- One armed setup, means that 95% of the time we are going to need to use groups with add destination service in order to nat the incoming traffic and avoid the asymmetric flow (the servers are going to respond always back to the CSS).
- What type of FTP are you going to balance?, passive or active?, if it is passive, with the add destination group is going to be enough, since the user is going to open the data and the control connection.
- If you are going to balance active FTP, we will need to NAT the incoming traffic (because you have a one-armed), and the outgoing connections, (because the server is going to open the data connection). Now we can assign the services just in one group, so, we need to choose: configure the group with add destination service (in order to nat the incoming traffic) or use the group with add service (in order to nat the outgoing traffic).
- The ACL on the CSS is not able to NAT the FTP port command (http://slacksite.com/other/ftp.html), so we need to use the group with add service because the group can NAT the PORT command.
- Since we have a one-armed, what happen with the incoming traffic?, since I am already using the group with add service.
- We need to configure the ACL in order to do the ?add destination service?, and nat the incoming traffic, like the example that I posted.
All the traffic that the CSS is balancing needs to pass trough it, the incoming and the outgoing.
The best way to know if everything is going to work is configuring the devices, and start the tests.
Hope you have everything clear now.
- Rodrigo
Rodrigo,
Sorry about this but, i just want to make sure I understand:
The mail server is not always just accepting connections from the outside.
People on the inside are sending mail, so if my server is initiating the transfer of mail, there is no outside connection to reply back to the VIP.
Wouldn't my server send the mail out the service address as opposed to the VIP address with the "add service"?
