Header base load balancing on CSS
dattaram.prabhudesai
Community Member
Hello
I want to configure my CSS runing code 8.xx to load balance based on a string of in the http header.
The users are using mobiles to synchronise mail content. The sticky rule needs to be configured based on the authorization strings in the http header. The auth string remains unchanged during the session. Hence the user should be re-directed to the same content server.
The details of the string is" header offset 7" "length 30"
The application used here is MobileIron..
Has anyone worked on this before.
DP
Daniel Arrondo Ostiz
Hi Dattaram,
Unfortunately, the CSS is not capable of performing stickiness based on HTTP headers. It can just do it based on a cookie or a part of the URL.
Header stickiness, however, is supported on the ACE modules or appliances.
I wish I could give you a more satisfactory answer
Daniel
