How can i view the running configuration while i am in a different Virtual Context
EPHRAIM MANI
Level 3
Level 3
Borys Berlog
Hello
Unfortunately you can't see configuration of context A from context B. Even from Admin context. This is a part of role based access model. If you have access to both of contexts - just to "changeto A" and then you will get into context A and can see all information you need.
Jorge Bejarano
Level 4
Level 4
Hello Ephraim,
You cannot show the configuration from one context on another but on the Admin context at least you can invoke it like this:
Admin# invoke context show running-config
Hope this helps.
Jorge
