How TCP connection is handled by ACE
Jan Rolny
Level 3
Level 3
Hi all,
I have simple question to ensure if I think that properly.
Here is this situation :
client----ACE----server1
                   \--server2
When client initiate TCP connection it starts standard 3-way handshake so it send SYN to ACE(VIP of serverfarm) first.
Question is, will ACE forward this SYN to server immediately or ACE will wait also for data from client?
I think that it pass through ACE to server. Server respond with SYN/ACK and client answer ACK back to server. After that data are sent.
Is it correct?
And 2nd question what if server send FIN+ACK and client sends RST. Will ACE reset the rest of this connection?
I appreciate your answers.
Jan
Kanwaljeet Singh
Hi Jan,
If it is a L4 connection then yes ACE will forward SYN immediately and if it is L7 then there will be delayed binding meaning there will be a separate front end and back end connection as ACE needs to wait for L7 information to take a LB decision.
If client sends the RST then yes the connection would be closed.
Kanwal
Kanwaljeet Singh
Hi Jan,
Kanwal
Hi Kanwal,
thanks for quick response.
Just another question. So in case of L7 connection between ACE and server, source IP will ACE IP not client IP. Correct?
Jan
Hi Jan,
If you are using source natting then yes otherwise client IP would be used.
Kanwal
