how to enable debug output on CSS 11500 switch
san_dec21
Thanks in advance
Can someone help me how to enable or configure debug outout on css switch,because i want to see the logs or what happened in real time when client hits the vip address configured on css switch?
In short i want see the debug output just like we can see with router.
Gilles Dufour
the CSS is not a router and is not troubleshooted like a router.
There is no 'debug ip packet'.
We could turn on some debugging but for sure if you have too much traffic you will kill the box.
There is no option to filter for a particular host.
If you have an issue, you should get a sniffer trace between client-CSS and between CSS-server.
Then we can compare the 2 and using your config figure out what is wrong.
If you just want to make sure everything works correctly, get a 'show summary' and 'show service summary' and see which counters are increasing.
Gilles.
Hi,gilles
thanks for reply.
