How to log within css 11000 scripts and send that info to sys.log file
matany
Hi, I am looking for a way to create log file with a script in css 11000. Is this possible? I am having a problem with my services which are using ap-kal-httplist keepalive script. But, they are showing as dying in the sys.log file.
pknoops
Level 3
Level 3
The answer to your question is unfortunatly no.
As far as a keepalive script goes, you cannot log to a file, however, you can change the logging of the CSS to reflect keepalive level logging which may help
logging subsystem keepalive level debug-7
Pete Knoops
Cisco Systems
